mopar_4life
Hello All,
I'm going to be converting my front drum brakes to disc brakes on my 65. I have been looking for a great replacement brake booster. I came across this
1970-74 Mopar Cuda E-Body & 1971-74 B-Body OE Style Brake Booster & Master Kit | eBay
So here is my question. Will it bolt up to my 65? I did go to their website. They list a bunch of options.
PB8536-2 - 1971-1974 B&E Body Mopar Bendix Style Brake Booster
PB8536-1 - 1966-1970 Charger Mopar B Body Bendix Style Power Brake Booster
1959-1971 Early Model Dodge D100/ D200 & Chrysler Full Size Car
I called them to find out some information about them and the salesman told me not to waste my money and I can use my drum booster with a disc master. He said it would not be in issue and should work fine. From what I read before on this forum is that I would need to have a disc booster as well as a disc/drum master.
Just for reference the disc kit that I will be running is:
Mopar C Body Front Disc Brake Conversion Original 4 Piston
I would go their entire kit with booster, but I called and it requires the use of manual brake firewall (toe Plate) mounting plate. I figure if it requires that it might require a manual brake pedal.
Mopar C Body Power Front Disc Brake Conversion Original 4 Piston
Hopefully the vast knowledge of this forum can help me figure it out.
Thanks
Eric
Thanks
Eric
