Rear axel messurements
Glider
Tollarp Sweden
I've been looking at lists of dimentions of rear axels such as this one:
In this list the numbers looks more like metric but that don't seem right at all...
& I don't understand it when I look at my messure tape.
71Polara383
Kid with ballcap
Rockford,IL
Maybe this will help ya understand.
Just because its got decimals doesn't mean it's metric.
Not sure of the source of that chart, but I would trust what's in the Mopar Performance Race Manual, personally. Interesting that the particular chart does not have C-body 8.75 rear axles listed, only "others".
The dimensions in the chart are not metric, but "inches". Do position them against the "rear track" measurements in the sales literature/FSMs for reference.
The spring width dimension can be altered by a competent race chassis shop, usually. Just have to ensure that they get welded back on at the desired width AND to allow for the correct pinion angle.
Glider
Tollarp Sweden
What I mean is that if I messure for example 45,3/8 inches & I then try to compare that to the list I found & showed in the first post I just can't see that as inches too...
What you do is convert the fraction part of the measurement into a decimal point figure. 3/8" is .375", for example, or to round it off a slight bit, .380" . Or divide 3 by 8, as the fraction would indicate.
