I don't understand the problems with these seals, I'm most likely jinksing myself but have never had one leak. Clean the whole area with brake clean must be clean, clean, clean. Put a very thin layer of Mopar black rtv, permetex ultra black rtv, or victor rtv(the silver stuff) in the groove. Put the bottom half in block lip facing forward, leave one side sticking up approx 1/8 to 3/16 of an inch, put a light film of oil on lip don't get it all over everything you cleaned. Put crank in and do the deal on it torque, thrust, ect. Same deal on cap clean, clean, clean thin layer of rtv in groove, put seal in cap with the opposite side sticking out 1/8 to 3/16 same as what you left out on other half, small dabs of rtv on butt ends and cap mating surfaces. Now take remainder of the rtv tube with the plastic nozzle cut at small size and run a bead up the grooves on each side, then bolt cap on, grab the rtv and force a bead into and on the bevel on cap to block edge wipe it smooth and if there is no oil should lay down like the caulking around your bath tub. Let this dry the whole 24 hrs before running engine keeping oil away from it. Throw the side seals in trash.
