Rear window Seal
Exterior, Paint & Bodywork
  1. Ralph Johnson
    Ralph Johnson New Member
    6
    0
    Aug 9, 2018
    Pahrump Nevada
    Hello I'm new to the site. I have a 1966 Chrysler 300 with a broken rear window. I found a window to but having problems locating rear window seal. I found a listing on line for a rear seal for a 1966 Newport and was wondering if this seal would fit the 300.
  2. Mike66Chryslers
    Mike66Chryslers Active Member
    393
    151
    Apr 28, 2012
    Ontario, Canada
    Welcome to the site!
    From your avatar picture it appears your car is a 2-door hardtop. Sorry but no, your 300 rear window is very different (smaller) than the 1966 Newport rear window.
    If you can't find a correct one, perhaps you could buy the Newport gasket, cut it down to size and glue it back together? I think the gasket is made by Steele Rubber. You could try contacting them and asking for their advice.
  3. Ralph Johnson
    6
    0
    Aug 9, 2018
    Pahrump Nevada
    thanks for the advice saved be from spending $400. on a seal that won't fit
  4. FURYGT
    FURYGT Senior Member
    1,861
    778
    Mar 11, 2017
    Middletown, CT
    I believe that the rear window on the 66 300 is larger than on the Newport so cutting down a Newport gasket is not going to work. Check with a company that I think is called Clesters. They sell many of the windshield and rear glass gaskets.
    Clester's Auto Rubber Seals
    They don't list your gasket in their catalog but that does not mean that they don't have it or can't make it if you send them your old one. I know that they made a rear window gasket for a friend's '67 Fury several years ago but they don't list that gasket in their catalog.
    I also found this on eBay for a '65 but I don't know if the '65 300 and other C Body cars used the same rear glass.
    1965 Monoco Polara Fury Chrysler 300 Newport 2dr Hardtop Rear Windshield Gasket | eBay
    Good luck.
  5. commando1
    commando1 Sergeant at Arms FCBO Gold Member
    30,988
    16,340
    Mar 10, 2011
    Fumbuck County - Sebring, Florida
    You need an interchangeable manual for glass to make sure.
  6. Big_John
    10,691
    5,634
    May 21, 2013
    Marcellus, NY
  7. Mike66Chryslers
    393
    151
    Apr 28, 2012
    Ontario, Canada
    I'm pretty sure that the 66 300 rear window is smaller than the Newport. It doesn't go all the way to the edges of the C-pillars, and it doesn't go all the way down to the bottom of the rear deck.
    The 66 300 used a unique roofline, which was not the same as a 65 300. I think they may have reused that roofline on 67 Furies which did not get the fastback roof. You'd need to check glass interchange part numbers to be sure.
  8. MarPar
    MarPar MeatMan FCBO Gold Member
    4,253
    3,874
    Apr 22, 2015
    Trapped Under Ice
  9. FURYGT
    1,861
    778
    Mar 11, 2017
    Middletown, CT
    Early morning pre-caffeine brain fart. Was thinking about the 66 300 4_door hardtop that I used to have.
    • Like Like x 1
