relay help
Imperial
  1. DusterKid
    DusterKid Member
    77
    7
    Nov 6, 2017
    Keymar, MD
    What does this relay do? I tried looking up the number online but couldn't find anything. Pulled from a 72 imperial.
  2. Big_John
    11,821
    6844
    May 21, 2013
    Marcellus, NY
    • Thanks! Thanks! x 1
  3. HWYCRZR
    HWYCRZR Senior Member FCBO Gold Member
    1,577
    2235
    May 13, 2015
    Fargo, ND
    Start with the Parts manual as Big John recommends. There should be a numerical section that will point you to what it is.
    It is helpful to know what part of the car it came from? Under the dash? under the hood? any wires connected to it? If so what color. Sometimes the electric schematic in your FSM can help track down the name and function of it as well.
    • Agree Agree x 1
  4. DusterKid
    DusterKid Member
    77
    7
    Nov 6, 2017
    Keymar, MD
    was under the dash
  5. DusterKid
    DusterKid Member
    77
    7
    Nov 6, 2017
    Keymar, MD
    should the number I'm looking for be the 3513581 or the 93596-A? I've found 2 online with the 93596-A part # but the top line is different. They are the headlight on relay
  6. HWYCRZR
    1,577
    2235
    May 13, 2015
    Fargo, ND
    The top 7 digit number is the Chrysler part number.
    The bottom could be a vendor p/n but I am not 100% sure.
  7. 70NEWYORKER
    70NEWYORKER Well-Known Member
    537
    386
    Jul 6, 2017
    Northern Illinois
    I checked parts books "69 to "73...not listed anywhere....
  8. Yeahrightgreer
    Yeahrightgreer Well-Known Member
    992
    605
    Oct 16, 2017
    Camp Lejeune, NC
    Looks similar to an early Headlamp/Key Buzzer
  9. Mopars & Missiles
    Mopars & Missiles Well-Known Member
    624
    592
    Mar 30, 2012
    USA
    Relays have MORE than 2 terminals. This is not a relay.
    I don't know what it is, but it MAY be a timer/delay type of device. One terminal for the +12V or signal input and the other terminal for the signal output. Ground would be through the metal case to chassis.
    • Agree Agree x 2
  10. Not Right
    Not Right Member
    168
    124
    Dec 14, 2017
    Independence, Virginia, -USA
    A flasher unit or buzzer??
  11. ImpJay
    ImpJay The different young FCBO Gold Member
    2,377
    1262
    Jun 4, 2018
    Vantaa, Finland
    Turn signal buzzer seems to be at least close.
  12. marty mopar
    marty mopar Well-Known Member
    532
    113
    Nov 12, 2010
    not in the part book and the only post on google with that number is this post on Cbodiesonly.com!!!!!!!!!!!!!!!!!!!!!!!!!
    often part #s on relays are not in the part book so this is not unusual.
  13. Not Right
    Not Right Member
    168
    124
    Dec 14, 2017
    If I remember correctly, there is one of those (similar in size and shape) attached to the back of the instrument cluster on a '68 Fury....and it had to do with 1. Instrument panel lighting, 2. Alternator gauge, or 3. Fuel gauge.............senility really, Really sucks!. As previously pointed out ( I think) Don't relays need to have 3 spades (plus a possibility of also providing ground to the solenoid via the metallic case/attachment bracket)? Whereas resistors, one way current check valves (diodes), circuit breakers, buzzers, and by-metal flasher units all use two spades........... Take it to a reputable CB Radio shop and invite him in on the quest. He will have many avenues with which to test the thing without cooking it. BTW, is there anything on your car that is now NOT working?
  14. commando1
    commando1 Mr. Normal FCBO Gold Member
    32,460
    17699
    Mar 10, 2011
    FUHOA Reservation, Sebring, Florida
    I believe you are remembering the instrument voltage regulator which this is not.
    • Agree Agree x 1
  15. vdk2010
    vdk2010 Senior Member FCBO Gold Member
    2,882
    1435
    Sep 26, 2012
    Frankfurt, Germany
    I ran into the same problem while parting out my '72 Imperial parts car. It's not mentioned in the Parts Catalog, but it's in the Wiring Diagram.
    Its the Head Lamp-On Reminder Buzzer Relay (Without Head Lamp Sentinel Only)
    1972 chassis Service Manual Page 8-176
    • Thanks! Thanks! x 4
    • Like Like x 2
    • Agree Agree x 1
  16. Not Right
    Not Right Member
    168
    124
    Dec 14, 2017
    So that's it? VDK2010, you solved the mystery? And no one has properly thanked you? What wrong with you guys?!??? Where's that Duster Kid anyway (the one who asked "What is this?"??
    Mr. VDK2010, on behalf of all of us who have gotten involved in this thread, I would like to THANK YOU VERY MUCH for providing the answer in such a definitive way.
    • Thanks! Thanks! x 2
  17. Not Right
    Not Right Member
    168
    124
    Dec 14, 2017
    DING, DING,DING....You win a seegar. You guessed right.
  18. Yeahrightgreer
    992
    605
    Oct 16, 2017
    Camp Lejeune, NC
    *Silently Sips Tee*
