Removing/replacing the heater unit on 68 fury
Heating, Cooling & AC
  1. Knebel
    Knebel Senior Member
    1,320
    261
    Mar 21, 2013
    Beaverton, Oregon
    I have a question regarding the blower and heater unit in my 68Fury III. The car originally had an AC which is no longer persent and I rarely drive it to the extend that I really need the heater either, except a windshield defrost is 100% necessary. So this isn't a question for the purists....
    I can imagine that this whole under dash unit is fairly heavy, has anyone removed it before and maybe replaced it with one of those smaller and lighter "hotrod heaters"? I am wondering how would one make it possible to attach the ducts for the windshield and such to a heaterbox like that?
    I would love to put an AC back into my car but thats way to expensive for what its worth.
  2. live4theking
    live4theking Old Man with a Hat
    11,776
    3818
    Nov 24, 2014
    Rockland; Venango County Pennsylvania
    They are quite heavy, at least the one in my NYer, isprobably between 40 - 50 pounds. I have no idea how one of the hot rod ones hooks up. There is a tread where I retrograde my AC system to have a Sanden compressor. I had about $500 in it and did everything but the charge on my own. The charging cost me about $125. I don't know the exact cost because I had some other work done at the same time.
    Converting from RV-2 to Sanden
  3. mrfury68
    mrfury68 Senior Member
    1,347
    487
    Jul 15, 2015
    Bethel Park PA
    Is your heater core leaking? If it is not leaking and your blower still works you can use it just for heat and defrost.
    • Agree Agree x 1
  4. Knebel
    1,320
    261
    Mar 21, 2013
    Beaverton, Oregon
    No its not leaking, its its just about saving so e weight and space.
  5. mrfury68
    1,347
    487
    Jul 15, 2015
    Bethel Park PA
    I would leave it as is. It is a lot of work to remove those old A/C units. Sure they are a little heavy but the space they take up is out of the way and really can't be used for much else. Just my 2 cents worth.
    • Like Like x 1
  6. Knebel
    1,320
    261
    Mar 21, 2013
    Beaverton, Oregon
    sounds like more trouble than its worth.
  7. LeBaron1973
    LeBaron1973 Old Man with a Hat FCBO Gold Member
    6,295
    889
    Sep 13, 2015
    Harewood, Christchurch, Canterbury, NZ
    As the old saying goes - If it works don't fix it -
    You'd replace it if/when it begins to leak.
    • Agree Agree x 2
