Yes they are probably hiding back under the seat, mine where. If I remember correctly because my '66 300 would be the same. I was on the driver's side of the bench, push down while pulling toward you. The whole bench bottom will come out and then if you need to, the back will come out by simply lifting straight up. My 300 is a coupe but I would think it would be the same.
