The reading will be affected by the tire diameter. You can get different plastic gears for the end at the tranny, but not easy to find today. In my 65 Newport, after a speedo rebuild I adjusted it to read correct at 60 mph, which is the region I really care about. There is a little adjustment tab you can slide on the needle assembly to change the zero offset. I was able to push it with a little screwdriver with the cluster in. I recall I had to lower down the steering column each time, but that is easy (2 bolts). My cluster has the speedo that wraps around the column in a 180 deg arc, and yours is surely different. To measure true speed, hold the car steady at 60.0 mph and time between mileage markers on the interstate and adjust until you measure exactly 60 sec (1 mile/min).
