Teach Me about Power Steering
Brakes, Suspension, Rims and Tires
  1. bajajoaquin
    bajajoaquin Senior Member
    1,390
    395
    Dec 6, 2013
    San Diego
    My Imperial has always had a bit of a leaky power steering system. I replaced a hose, but it still leaks. Now, after I’ve driven it a bit, it doesn’t have much power at idle (like when parking) and makes noise. The reservoir is low-ish but not low. It’s over the vanes in the pump and just needs a little topping off.
    What are the symptoms of steering boxes going bad? Just the pump? Aren’t there two types and one can (should?) be converted to the other?
  2. jeffsunzeri
    jeffsunzeri New Member
    26
    6
    Dec 5, 2018
    Hollister, CA.
    Worn out PS pumps show the symptoms you describe: poor performance at idle, belt chirping.
    You should not convert one pump type to another. Stick with what the factory installed.
    Fix all the leaks, especially if in the high pressure hose.
    The pump will usually go bad before the box does. When the steering box goes bad you get wandering steering, inability to maintain alignment, leaking at the box and overall sloppy steering.
    Make sure to use the correct fluid so you don't ruin the seals.
    • Agree Agree x 1
  3. Davea Lux
    8,036
    1978
    Mar 27, 2017
    Cornelius Or
    Avoid buying a rebuilt pump from Blotto Zone or similar low quality suppliers. Most of the low end pumps by Cardone and others are rebuilt overseas and the quality is very poor. If the fluid in your existing pump is contaminated or the wrong type, it will also cause the symptoms you describe due to the fluid foaming. Start by purging the old fluid and replace it with the correct type.
    • Thanks! Thanks! x 2
    • Agree Agree x 1
  4. rags
    rags Senior Member
    1,047
    613
    Dec 14, 2015
    greater norwich metropolitan area
    the above can not be overstated. better with junkyard used o.e.
  5. bajajoaquin
    1,390
    395
    Dec 6, 2013
    San Diego
    Is there a correct power steering fluid other than “power steering fluid?” I’m guessing that ATF is a no-no.
  6. Davea Lux
    8,036
    1978
    Mar 27, 2017
    Cornelius Or
    The correct Chrysler power steering fluid was part #2084329. It has anti foaming additives and other additives to keep your power steering pump from overheating. You should never use ATF in mid 60's to mid 70's Chrysler products. This oil is now an obsolete item unless you happen to get lucky and find it on e-bay. I have been using the modern semi-synthetic stuff which seems to work ok. If you decide to go that route, flush out as much of the old oil as possible.
    • Like Like x 1
  7. Davea Lux
    8,036
    1978
    Mar 27, 2017
    Cornelius Or
    Lucas oil power steering fluid #10823 pints,#10824 quarts. is the one I have been using.
  8. bajajoaquin
    1,390
    395
    Dec 6, 2013
    San Diego
    So a specific recommendation for Lucas or a general pointer to specifically-labeled power steering fluid is what I think I read there, right?
  9. bajajoaquin
    1,390
    395
    Dec 6, 2013
    San Diego
    Maybe I don’t have a leak any more. Maybe I am just roaming out the top because (yes, I’ll admit) I was using ATF.
    Flushing.... best way?
  10. jeffsunzeri
    26
    6
    Dec 5, 2018
    Hollister, CA.
    ATF type F is specified and correct for early Chrysler and Imperial power steering systems. What year is your Imperial?
  11. bajajoaquin
    1,390
    395
    Dec 6, 2013
    San Diego
    1967. I was using type F.
  12. jeffsunzeri
    26
    6
    Dec 5, 2018
    Hollister, CA.
    By 1967, MoPar was recommending the MoPar fluid. Using Type F ATF is not going to hurt anything, but it would be a good idea to change it out during your next maintenance interval to the modern synthetic PowerSteering fluid available on all the parts store shelves. ATF+4 will work well too.
  13. 70bigblockdodge
    70bigblockdodge Old Man with a Hat FCBO Gold Member
    12,487
    5317
    Jan 19, 2013
    Avonmore Pa.
    Anything but a Saginaw ps pump should be for restorations only. No reason to put up with those garbage federal and TRW pumps on a driver.
  14. Davea Lux
    8,036
    1978
    Mar 27, 2017
    Cornelius Or
    The Lucas oil power steering fluid is the best I have found so far as an after market product.
  15. 75LandYacht
    75LandYacht Yank Tank FCBO Gold Member
    4,407
    2220
    Oct 1, 2015
    Westchester NY
    I’m glad you brought this question up Bajajoaquin.. my 77 NYB power steering chatter and wines when turning at idol sometimes, not all, but enough to concern me. Fluid is topped off, no leaks. My high pressure line needs replacing, it’s frayed a bit.. so the above info is greatly welcomed.. thx guys.. But! If “Part store” pumps are Taboo! Where does one get a new / replacement or have my existing one rebuilt????
  16. Davea Lux
    8,036
    1978
    Mar 27, 2017
    Cornelius Or
    AC Delco reman pumps are generally pretty good. You will need to see if they have your particular unit. Saginaws are usually no problem, the Federal and TRW units they sometimes do not have. I have also found the less common pumps rebuilt at www.powersteering.com. www.larescorp.com as does quality custom rebuilds. If your pump is just leaking, a lot of times you can simply buy a reseal kit to repair it.
    • Thanks! Thanks! x 1
  17. Davea Lux
    8,036
    1978
    Mar 27, 2017
    Cornelius Or
    The easiest way to flush the power steering is to disconnect the return line from the pump and block off that port. I use a splice connector to hook a piece of 3/8" transmission cooler hose to a capture container on the floor from the return line. Next start the engine and run it until the return line stops spitting oil. Refill the PS pump and repeat until clean fluid is all that comes out. Be sure to move the steering wheel back and forth to get old oil out of the gear. Reattach the return line to the pump and you are good to go.
