kawdude
History first..... 68 newport covertible 383 2bbl 22 inch radiator. sat since 89, cooling system dry. i bought the car, lubed the cylinders, new plugs runs very well. Checked brakes, and all fluids, new oil and filter, did some repairs on floors new tires. I have flushed the radiator, flushed the block the best i can with a garden hose through the top and bottom rad hoses flushed radiator added prestone flush, ran till got warm, shut off let cool, ran till warm etc a few times, flushed all again, new hoses, new thermostat, new spring in lower hose, new water pump, new rad cap (16) tried a 7 pound cap, new heater hoses, new sunpro temp gauge, drive the car 5 miles or less, car overheats, top hose hard as a rock, pushes water out into a catch bottle i put on, when it cools down draws water back into system. i pressure tested the system tested ok, left pressure tester on warmed car up, thermostat opens, rev car pressure does not increase. water does not seem to me to move alot in the radiator after the thermostat opens. i been a mechanic most my life but im stumped on this....
Any ideas?
Posted via Topify on Android
Any ideas?
