Turn signal help
rjstick
Charlotte, NC
Hi. I'm trying to replace a grill mounted turn signal bulb but can't figure out how to remove it. 68Plymouth Fury.
Before I do something stupid I thought I'd ask the group. Does it just pull out from the rear? Doesn't seem to want to come out that way and I don't want to break anything.
Thanks!
same issue
I was going to post on that same issue! I have a 67 fury I'm trying to change it on. I've turned it and pulled it but I still can't remove it. Anyone have a clue? You can see all my wrench marks.
Have you tried taking the lens off and pushing the bulb in and twisting counterclockwise?
That'd be my guess.
I have a bulb out on my 11 RAM & can you believe that you have to remove the grill & then the entire headlight assembly? Who's the genius.......
Don't know but just looking at your pic can you pry it apart when the base connects to the cup i.e. using a flat blade screw driver?
To replace the DRL on a C6 Vette, you have to remove the fender...
No, no, no....
Step1. you post a thread on the Corvette forum.
2. Everyone tells you that you have to go to the dealer.
3. They start recommending dealerships that they go to... usually at least a thousand miles away.
4. You take the Corvette to the local dealership and they charge you $1000.
5. You Zaino your car and post pictures on how shiny it is in the sunlight.
I think with a 68 Fury you have to reach through the grille with a long phillips screwdriver to remove the housing from the grille and then take the lens off. Pull the bulb out from the front. It's been a long time though since I've seen one though, so I may be wrong.
B.J. You just sparked a memory. The socket can't be pulled out.
Here we go:
"The majority of the bulb sockets in taillights,turn signals,and cornering lamp assemblies are permanently stamped or pressed into white metal,potmetal or aluminum housings. "
http://www.moparfins.com/forum/forum_posts.asp?TID=3741&title=how-to-fix-unrepairable-bulb-sockets
Thanks for confirming. I got to the same conclusion trying everything I could think of to remove the bulb socket from the housing.
you must remove the parking light from the grille they are held in by a headless bolt with a nut on the backside which you can reach from the backside. then remove the lense to access the bulb
