WARNING -DON'T DO THIS TO YOUR WASHER RESERVOIR!!!
Fuselage Years
  1. Not Right
    Not Right Member
    168
    125
    Dec 14, 2017
    Independence, Virginia, -USA
    Well, it's story time again kids. I know some of you may have already heard this story before, but I thought I would orate it once more. You see, in researching plastic septic tanks and septic chambers the other day, I learned something very important about plastics.., specifically HDPE Plastics. (High Density PolyEthylene).-Besides offering the septic components made of black HDPE, this one particular company also offered "Fresh Water" storage tanks and paraphernalia. So, of course, I wander out into the weeds, so to speak, to go read about and look at that stuff. DID YOU KNOW?:The frosted, milky white plastic used in these Fresh Water Storage Tanks is the same HDPE used to make our Washer Reservoirs. It's been around for a long, long time. I learned that HDPE Plastics come in different colors...each color denotes certain tolerances of that particularly colored plastic. Well, the Frosted, Milky White HDPE has a heat tolerance of 120*F, above which, it will begin to turn clearish, then distort, then begin to slightly shrink, and then develop tiny little check marks which turn into gaping cracks. After going through all of that process, the plastic then brittles out.-Last spring I found the Holy Grail...a beautiful, supple, succulent 3431154 Reservoir at Newton's Garage in Cloverdale, Virginia. (3431154='70-'73 C Bodies). Even the metal bracket on it was still wrapped in the factory black paint. Needless to say, I got it home and set it on a red velvet draped pedestal in the front foyer, complete with accent lighting. About a month later, I decided to wash it real good and make it as pretty as it deserved to be. SOooo, I filled the kitchen sink with hot water and some Dawn detergent. I immersed the Reservoir in the hot, soapy water. After a couple of minutes, I began to notice that my bottle-brushing was really making a difference.., heck, I could see right through the plastic now! "Is that Right?", I thought to myself. NO, it was NOT RIGHT. It self destructed right before my eyes. THEE END. Pass it on.
    • Thanks! Thanks! x 4
  2. commando1
    commando1 Old Man Wearing a Hat on the Porch FCBO Gold Member
    33,157
    18235
    Mar 10, 2011
    FUHOA Reservation, Sebring, Florida
    Can't overcome the age factor. You can keep HDPE in an airtight sealed container but after 40 years their crystalline structure still breaks down.
    Everytime I put place something on a pedestal, they fall off.
    Sorry to hear about this expensive tragedy.
    • Agree Agree x 2
  3. Wollfen
    Wollfen Old Man with a Hat
    6,373
    3297
    Jul 18, 2012
    Greenville NC
    • Like Like x 1
    • Agree Agree x 1
  4. jollyjoker
    jollyjoker Member
    173
    71
    Nov 15, 2016
    Ohio
    Another question, along these same lines . . .
    Has anybody tried mildly "aging" a reproduction washer bottle? I have a nice one ready to slip into my Dodge, but really hate that really bright white look in my clean, but vintage engine compartment.
    Have pondered a few options . . . fill it w/ some strong coffee or tea and let it sit a few days? Maybe a little Rit dye? A little orange-brown food coloring? Any suggestions out there?
    Whatever I do . . . I'll make sure I use COLD water!:D
    • Like Like x 1
  5. 300rag
    300rag Grumpy Old Man With a Hat FCBO Gold Member
    11,440
    12333
    Dec 4, 2010
    Calgary, Alberta, Canada
    Not that I would try it, but tea would stain better than coffee. At least in ceramic mugs it does.
    • Agree Agree x 1
  6. cm23uoc
    cm23uoc Old Man with a Hat
    8,380
    2439
    Feb 13, 2011
    I would just naturally let it age in the engine compartent over the years and fill it up with the proper mix of water/cleanser.
    • Agree Agree x 3
  7. Not Right
    Not Right Member
    168
    125
    Dec 14, 2017
    I guess there's just no way around it. Dooh! :BangHead:
  8. Fury440
    Fury440 At my age everything's a good idea FCBO Gold Member
    2,641
    2037
    Jan 15, 2011
    Calgary, Alberta
    The sad part, I acquired a mint washer bottle in 2000 and attached it to the front fender to ensure it didn't get lost or broken. In 2013 revisited it only to discover it was totally brittle and completely useless. So all those guys flogging NOS bottles for $600 are a joke. i'm either going for a new reproduction, or a large pop bottle.
    • Thanks! Thanks! x 2
    • Like Like x 1
    • Agree Agree x 1
  9. Ross Wooldridge
    Ross Wooldridge Senior Member FCBO Gold Member
    2,562
    764
    Apr 25, 2016
    Scotland, Ontario, Canada
    New repro is the way to go, and apparently on some models they sell one that is coloured to look aged...
  10. stubs300
    stubs300 Senior Member
    2,063
    862
    Oct 30, 2011
    Free America
    The plasticizers in plastic will naturally dry out, there's nothing you can do to stop it, this is fact! Heat and sun will accelerate the process even faster. It's a part of life that you have to deal with! To bad straws can't breakdown that quick!
    • Agree Agree x 1
  11. '69FuryIIIConvertible
    '69FuryIIIConvertible Senior Member FCBO Gold Member
    3,684
    2985
    Oct 18, 2012
    Ajax, Ontario, Canada
    I've bed experimenting with a way to protect a good original.
    My thoughts are dipping or spraying it with some type of clear epoxy resin. This giving it a protective outside coating.
    It's still only in its infancy
    • Like Like x 2
  12. Fratzog
    Fratzog Old Man with a Hat
    10,492
    5144
    Nov 12, 2010
    Grimsby, Ontario, Canada
    I'm wondering if keeping washer fluid in them has any effect. Both of mine in the cars seem fine and have been sitting empty since I've had the cars. They are there just there just for appearance purposes. The only time the wipers get any use is the once in a blue moon if I get caught in the rain.
    • Agree Agree x 2
  13. jason99
    jason99 Active Member FCBO Gold Member
    440
    179
    May 20, 2018
    Atlanta, GA
    It seems like washer bottles would really be in the sweet spot for 3D printing style reproduction. I wonder if anyone has went that route.
    • Agree Agree x 2
    • Like Like x 1
  14. CBODY67
    CBODY67 Senior Member
    4,139
    966
    Mar 27, 2011
    Back in the later '80s, several guys in our Mopar club were searching for useable/not crazed Challenger door panels. Seems that every white ones they round were all chalky and ready to crack apart. The black ones were in much better condition, for the same model year of car.
    One our the guys researched the plastics and discovered that the black plastic has all of the UV-fighting characteristics to stay in good condition longer, but those protecting chemicals are not there in the white plastics. Hence, the deterioration of white plastic far quicker than similar items in black.
    Admittedly, the washer reservoirs were molded thinner in some years than others. But the coolant reservoirs were thicker, still "white", but obviously could tolerate 200 degree coolant hitting it. Then now we have pressurized coolant reservoirs with a radiator pressure cap on top of them. Obviously thicker material, but also more "clear" than "milky".
    • Like Like x 1
  15. commando1
    33,157
    18235
    Mar 10, 2011
    The breakdown starts from within. Shielding it from external forces doesn't help.
    • Agree Agree x 4
  16. commando1
    33,157
    18235
    Mar 10, 2011
    That goes for life also, son.
    • Agree Agree x 5
  17. Turboomni
    Turboomni Senior Member
    4,756
    2349
    Dec 14, 2015
    MA
    Does that mean we are all going to die??
    • Disagree Disagree x 1
  18. Wollfen
    6,373
    3297
    Jul 18, 2012
    Greenville NC
    Not me!
    • Like Like x 3
  19. CBODY67
    4,139
    966
    Mar 27, 2011
    Some things are inevitable, BUT the ticking clock can be slowed down with stress relief. Keep your MOPAR HAPPY and you'll be happier, too. And, of course . . . . decrease carbos, watch salt, and MOVE (which Mopars enjoy doing, too!). Just like Mopars, you'll move better with less weight to carry around!
    Happy NEW Year!
    CBOdY67
  20. Fury440
    2,641
    2037
    Jan 15, 2011
    Calgary, Alberta
    Well I don't know, mine sat bolted to the feder, empty. In fact the whole engine was removed so there were no strange chemical vapours etc. The garage was heated to 55F. After 14 years in this storage heaven, my pristine nice and flexible bottle became hard and brittle. So brittle that even a light touch damaged it.
    Maybe I should have kept it filled with bug juice. I don't really have any suggestions.
    • Like Like x 1
