What Carb for my 78 C-Body?
  1. NCGNETO
    NCGNETO New Member
    31
    3
    Apr 4, 2011
    Boise Idaho
    I have a 78 Newport that I plan on Stroking later this year if business stays good. I was looking at some Edelbrock Carbs but have no idea. I was thinking a 600cfm. What would I do with the electronic stuff on the side of the intake after I do a different carb?
  2. commando1
    commando1 Mr. Normal FCBO Gold Member
    31,957
    17301
    Mar 10, 2011
    FUHOA Reservation, Sebring, Florida
    Man, this topic will really have all the Einsteins chiming in and arguing with each other.
    As far as this Einstein, this is what I think is the best bang for the buck. It ain't stroked yet and until you do a complete rebuild anything else is wasting time, money, and effort ( my 2ยข only - you get what you pay for as far as my advice).
    Replace the carb (keep the manifold) with a Holley or Edelbrock 750. I like Holley because I know them inside and out. Otherwise pick your choice.
    Replace the garbage distributor with an electronic setup. It comes complete and with easy instructions.
    Take the computr and beat it with a sledge hammer until you feel better.
    Replace the air cleaner unit with a free flow unit. 14 X 3 fits nicely.
    remove the charcoal canister. Leave line from gas tank unplugged or get a vented gas cap.
    remove air pump divertor valve
    remove vacuum amplifier
    remove vacuum reservoir
    disconnect CCEGR valve on top of the radiator
    remove vacuum solenoid valve
    If you have the Cali smog pump - I can't help you.
    [​IMG]
  3. NCGNETO
    NCGNETO New Member
    31
    3
    Apr 4, 2011
    Boise Idaho
    I'm on my way to vegas and I'm getting 10 miles to the gallon. I don't think my car has california emissions. will said removal give me more horsepower and possibly better gas mileage?
  4. commando1
    31,957
    17301
    Mar 10, 2011
    Yes. It may hit as high as 12 mpg downhill with a tailwind.
    Don't think of as only 2 extra mpg.
    Think of it as a 20% increase.:icon_lol:
  5. NCGNETO
    NCGNETO New Member
    31
    3
    Apr 4, 2011
    Boise Idaho
    HAHA!!! Is that all these cars get on the freeway?
  6. 1978 NYB
    1978 NYB Warfighter FCBO Gold Member
    40,874
    11796
    Apr 16, 2011
    Classified
    Commando - Question or two...
    You recommended an Edlebrock 750 or a Holley. I have a 400. Do you recommend a 750 for both a 440 and a 400? What do you think about an Edelbrock 600 (1406) with an electric choke for a 400? Of course with the adapter plate to go from a spread bore to a square bore. What model # Holley would you recommend for a 400?
  7. 1978 NYB
    40,874
    11796
    Apr 16, 2011
    Classified
    Commando - Question #2
    You recommended keeping the original intake manifold. Can I pick your brain a little deeper on that recommendation. Is it because the original manifold is easier to hook up all the rest of the stuff to original bolt holes and brackets like cruise control, throttle return, etc. Your thoughts on an Edelbrock Performer Intake and possible problems hooking up other brackets, linkage, etc.
  8. commando1
    31,957
    17301
    Mar 10, 2011
    Look at it this way: You're planning a major rebuild later down the road. At this point it would be foolish to try and pick a manifold. It has to be matched to the rest of the components. The carburetor you can use now and be pretty much assured that whatever way your build goes later on, the 750's will still be a good match.
    And yes!!!! Most of all, the simplicity. Plug & play.
    I said 750 because you said stroker, regardless of whether it's 400 or 440. Makes no sense to spend all the money on a stroker kit and try and get away with a 600.
    Personally, unless you're insane as I am, do a mild, smooth running rebuild. Clean up the block, do a valve job, check over the crank, rods, pistons, pushrods, and rocker arms. A mild cam, new lifters and an Eddie intake and carb, dual exhausts, and you'll be more than happy. RockAuto oil, fuel, and water pumps, gasket set and odds and ends. After all, it's a 78 Newport, not a 70 440 GTX.
    And I don't want to be the only one chiming in. After all, WTF do I know....
    Regardless of what carburetor model, just pick one with an electric choke and vacuum secondaries. Unless you're going racing.
  9. NCGNETO
    NCGNETO New Member
    31
    3
    Apr 4, 2011
    Boise Idaho
    Funny you say that car. My brother in law has a 71 440 gtx that I want to he able to at least keep up with.
  10. commando1
    31,957
    17301
    Mar 10, 2011
    [​IMG]" '71 440 GTX...."
    To make up for your extra 1,100 pounds of pork, you'll have to have an 185 HP advantage. Good luck......
  11. Polaraco
    Polaraco Member
    182
    27
    Jan 1, 2011
    Jersey
    There is no way you'll keep up with that GTX unless you are up to 600 cubes.
    You're wasting a pile of money trying to keep up. I'd say put your ego asside and ask him if he can get l --d in the back seat
    To do it right, it was going to cost $9K just in parts to stroke a 5.9 Magnum. + machining and I do the assembly.
    You can dig more ponies out by doing what Commando said. Also work on a good cold air syustem. Get the air from outside the engine compartment
    [​IMG]
