Anyone know if a set of 14" wheels from a 74 Valiant would fit my 66 Sport Fury?
'66 Sport Fury, probably drums, but never say never.It depends on the brakes too. If you have front discs, you can´t install anything smaller than 15`` wheels.
I have front disc brakes with a 14"stock rim on my 65 SF. No problem.It depends on the brakes too. If you have front discs, you can´t install anything smaller than 15`` wheels.
Correct, the 69 and up without the Budd discs require the 15 inch rimsI have front disc brakes with a 14"stock rim on my 65 SF. No problem.
All slant six cars to 76 with drum brakes got the poverty 5 on 4 rims. Yes disc brake cars were 5 on 4.51973 and newer A bodies(valiant) with disc brakes should have the standard 5 on 4 1/2 bolt circle. That is the same as your sport fury. I would still measure to be positive.
