Samplingman
From the factory, did it start with Formals or were they installed earlier?
Interesting.... Anyone have a pic of a 71 Fuselage with the overflow bottle? I'd love to add one to my car.1971......
Thanks... now I have to clean coffee off the computer, again.Couldn't you find one any uglier?
Good idea. How did you come up with that?Here is what I used - 1980 D100 bottle still available as new and I have a spare...
I still need to replace the hose but worked good looked ok. Better than peeing all over the driveway
Maybe you had a spare! Thanks again.Here is what I used - 1980 D100 bottle still available as new and I have a spare...
Mounting height. Hard to tell from the picture but it looks like the whole bottle is mounted lower than the top of the fluid level in the rad. If that is true wouldn't the bottle just siphon all your coolant?
It will only keep going until he pressure lowers to the rated cap PSI, then it will seal and start drawing back when it cools down.Maybe you had a spare! Thanks again.
Your radiator cap would have to be quite bad. The overflow/reservoir bottle is vented to atmosphere so that it does not siphon.Maybe you had a spare! Thanks again.
That makes sense. So as I understand a rad cap, the seal is held to seal the opening with a spring calibrated to hold to a max pressure. Once the spring releases coolant runs to the overflow tank. Now when everything cools down a vacuum will form in the rad as the coolant and engine block passages shrink. So .. how does the vacuum get past the valve cap spring loaded valve? Are there different types of rad caps depending on whether the rad vents to the street or to a closed system capture bottle? Sorry for the dumb questions, but I've never thought about this before and I'm wondering how it works.It will only keep going until he pressure lowers to the rated cap PSI, then it will seal and start drawing back when it cools down.
Ok, that answers another of my questions, ie why isn't the reservoir cap pressurized. I have seen, on some new cars, no cap on the rad, but a pressure cap on the reservoir. I'm guessing these are completely sealed systems.Your radiator cap would have to be quite bad. The overflow/reservoir bottle is vented to atmosphere so that it does not siphon.
