Timmayy
Hey all. Where is the voltage regulator on my 67 Fury wagon? Is it behind the dash? I'm overcharging on the highway.
circled in red. Sounds like you need a new one. If you don't fix it soon you will also need a new battery. Make sure it is properly grounded to the firewall.Hey all. Where is the voltage regulator on my 67 Fury wagon? Is it behind the dash? I'm overcharging on the highway.
Bet you're confusing the voltage regulator with the voltage limiter that supplies current to the gauges.That's what I thought. This is my first C-body. I tried looking under the dash like the B and A bodies. Thanks. It'll stay parked until I get a new one.
Ah, the old spray brake cleaner around the carb to find vacuum leaks. Always fun!I installed a new voltage regulator. All back to normal now. Went on a few test drives. Now it's idling like crap again. I'll have to look for vacuum leaks. It never ends.
