Window Motor Orientation - 68' 300 Convert RESOLVED
sprice
Winnipeg, Manitoba
I have looked in the service manual and they only show one side of the rear quarter window. My question is, are all the motors supposed to have the wiring orientated towards the bottom of the window cavity? Been so long since io removed these, I cannot remember and didn't take pictures. Right side rear appears like it could be mounted with the wiring pointed upwards. Thanks,
They should oriented in the same position from right to left, think mirror.
You are correct Detmatt. When I took all the motors off to recondition, I didn't notice the motors could be mounted either way on the mount brackets which is why I had two motors that looked like they should be mounted with wires upwards, instead of down. Reversed and back on track.
