Wiring Diagram
67commando
Ohio
Anyone have a wiring diagram for the dash wiring on a 67 Sport Fury 3 383HP with A/C, PS, PB??
Going to look at all available options. Long road ahead to get back on the road.
Ordered a color wiring diagram. Hope to get things figured out with the wiring. Car runs and starts but no lights. If anyone is in the Canton, Ohio area and willing to lend a hand let me know.
Check for voltage at the lights first. Check high and low beams.
Next place to check is dimmer switch. Check voltage to center connection and continuity to one or the other connection as the dimmer switch is worked.
Next place is the firewall plug. Check voltage to back and then to front.
The headlight switch has an internal circuit breaker.
I've had minor success spraying contact cleaner into it at the seam and actuating the switch a bunch of times.
Just be sure to disconnect the battery first.
Hope the input helps.
John
Would the light switch have anything to do with the brake lights not functioning?
Assuming the bulbs are good and the wiring is intact, a fuse would be the first thing to check. The Brake Light Switch on the brake pedal assy could be defective or possibly out of adjustment. Do the turn signals work? The turn signal switch is part of the brake circuit.
