WANTED 1968 Plymouth fury antenna
Shakerdave
Middle
I'm looking for an antenna for our 1968 fury. Doesn't have to work just needs to be correct to fit the hole properly. I've bought others that were supposed to fit but don't. Thanks.
To fit correctly, you need the correct bracket from a 1968 Fury that goes under the fender and the correct bezel that goes on the top of the fender. A 69-69 Barracuda bezel will work. Good luck.
68 a one year only...67 mounted in a smaller hole...I finally found a junkyard one and had the bezel rechromed...Vans makes a replacement nut cause most of the used ones have been removed with a hammer and chisel or visegrips....the nut is listed for 68-74 so MAYBE the later antenna will work if you can find the 68 bezel
