NOT MINE 1960 Plymouth Belvedere Sedan - £23,950 - Chesham, England
T-revorNobody
Sidewinder, Colorado
At the time of posting, this FB listing is 1 week old.
FB Description
The infamous ex Al Wilson 1960 Plymouth Belvedere NSS street/ strip car, big block 470ci stroker engine with Sonoramic Commando style ‘short’ long ram manifolds and dual Carter carbs. Torqueflite, SureGrip, Caltracs, discs all round and much more, Well known car with many NSS class wins to its name in the USA. Never been shown or raced in the UK Spec includes: 470 ci low deck big block engine (400 block with stroker crank) Aluminium main caps, built by Damon Kuhn, Diamondback Engines. Mopar Performance Aluminium 452 heads Milidon deep oil pan with external feed oil pump Factory ‘short’ Long Ram induction with dual 500 Carter Competition. Hughes Engines hydraulic roller cam BeCool aluminium radiator Sanderson ceramic coated headers FBO electronic ignition 60 Amp Alternator Switchable electric crankcase vacuum pump A727 push button transmission, 1965 with slip yoke output, A&A super sprag, solid 2nd gear band, needle bearing rear support, rear pump delete, Moroso pan, auxiliary cooler. Reverse pattern manual valve body ATI 10 inch Treemaster converter, 3200 flash stall Aluminium drive shaft with safety loop 8 3/4 E body rear (489 casting) Detroit locker, 3.55 gears, ESPO rear leaf springs Caltrac traction bars with Calvert adjustable rear shocks, 90/10 front shocks 4 wheel disc brakes(AAJ with Wilwood callipers front, Strange rear) adjustable proportioning valve, line lock on front brakes 16 gallon fuel cell, Mallory electric pump with priming switch Trunk mounted weight box Stock interior with A990 style lightweight bucket seats Older repaint has some blemishes and patina Solid original unrestored body in factory original colours A unique car with all the right bits Lots of paperwork, bills, copy of title and build sheet etc Owned and progressively developed by Al for nearly 30 years Ran consistent 12s with a best of 11.66 during Al’s ownership, check out MY 60 PLYMOUTH HISTORY The car is on the button, UK registered, ready to enjoy, i have driven it 25 miles from storage to home last week with no issues. It has working lights, speedometer, gauges and so on. Currently no park brake as it was set up more for race than street, thats probably the only MOT item it needs There is a pair of Mickey Thomoson slicks with the car Its noisy with a lumpy cam, its thirsty with a pair of Carter Competition carbs Dare to be different! Offered at just £23,950
