For Sale 1968 Dodge D100 Sweptline Awesome Custom Truck - $20500
tbm3fan
Pleasant Hill, CA
Custom patina skyrockets
This one-of-a-kind build is one of the nicest you will find.I bought this truck from the original owner. If you have had a stock old Dodge like this, you know they are factory leaf spring front, and drive poorly. This one is an exception and drives like a brand new truck with a full frame off custom independent front IFS with adjustable ride tech coil overs, rack and pinion, aluminum control arms, and big rotar disc brakes. It has a 8/3/4 rear end with 3:23 posi sure grip with 4 link and adjustable ride tech coils.The bed was cut out and moved up 6" and LineX in body color. It has a rebuilt 727 trans with holeshot converter. The truck has a steel crank big block 413 with a .484 Mopar performance purpleshaft, a true roller timing chain, full MSD pro billet ignition, Edelbrock intake, Holley 750 double pumper, dual snorkel air cleaner. It has big block HP manifolds, full custom exhaust which comes out the rear with stainless steel Magnaflow mufflers. The body has been competely re-done patina exterior with DuPont clearcoat. The underhood is all been stripped and painted in DuPont Chroma Premier paint, and under the bed has been stripped and painted same as underhood. Frame has been done in shiny black.There is new chrome on the dash and restored factory correct custom white wheel. New upholstery, seat and headliner. There is all new chrome. There is a small crack on dashpad. All the glass is good, and it has a tinted rear window. This truck has a set of very rare super coupe rally wheels with new tires under 2k miles.The truck sits 5" off the ground, has room to go up or down. It is very cool set up, all work has been professionally done, over 25K spent. It gets lots of looks and thumbs up everywhere I go, lots of power, fun, and comfortable to drive. Located in Yuba City.
Price is two times what it will likely bring. I like it! It also has the late '70s Super Coupe wheels, too. Nice!
