CudaJames69
1969 Plymouth Sport Fury , 383 2bbl , 727 automatic , power steering , power disc brakes & air conditioning .
I bought the car from New Mexico about 3 years ago . The car has minimal rust , has a hole in the center of the roof ( looks like someone drilled a hole in it ) has rust around front & rear windows due to vinyl top , front right floor pan has rust , right rear quarter just starting to rust . Trunk pan is perfect !!!!!!!!! As you can see the vinyl top has been removed .
I believe it is the original engine to the car . I will check the numbers over the weekend .
No brakes right now . Will work on that . Has power brakes , disc front & drum rear .
Mounted 4 good used tires Monday 8/22 .
8/24 Replaced the starter . Engine cranks . Charging a battery right now .
^^^Battery not included ^^^^
8/26 OK it runs . have it running off a gallon of gas . It goes into gear , drive & reverse . i won't try to move it yet since it still has no brakes .
8/27 Changed oil , ordered fuel filter , air filter , wires , idler arm & master cylinder .
8/29 Removed rug , cleaned floors
8/30 Cleaned seats & dash
8/31 Replaced ignition wires , cleaned seats & dash
Being a New Mexico car the interior need work . Complete but needs new seat covers , rug & dash pad . I will remove the rug to get pictures of the floor and clean the interior over the weekend .
Air conditioning not working .
Will get more pictures over the weekend . These pics are from Tuesday 8/23 .
It is presently registered in my name . I have a transferable registration in my name . New York has a transferable registration before 1973 .
Lost storage , would like to free up some room and downsize . Only reason for sale .
Thanks for looking
Thanks for looking
