NOT MINE 1974 Chrysler Newport - $5,700 (Crosby, ND)
67newport
eastern oh
not mine
1974 Chrysler Newport - cars & trucks - by owner - vehicle...
1974 Chrysler Newport, 4 door Sedan,
V8 gas 400ci big block, 3 speed automatic transmission, body not perfect, but good, very restorable, very clean underneath the car (very little corrosion), a couple of small tears in the top, otherwise good, all glass is good, starts, runs, drives, shifts, and stops very well.
In the past 2 years it received: new wheel bearings, ball joint, new wheels (I have all 4 original wheels and hubcaps and they go with the car), new tires, new carburetor, new aluminum radiator, new electric cooling fans, new heavy duty shocks, new master cylinder, new caliper, new rotor, new u joint, new heater core, new windshield wiper motor. In the past 3 months: 2 new spare tires, complete new exhaust system, new front brakes, alignment, new battery terminals, new starter, new alternator, transmission serviced (new fluid, filter, and pan gasket), new valve cover gaskets, electronic choke, new water pump, new thermostat, new upper radiator hose, regular oil changes. About 110,000 miles, no A/C, manual windows, locks, and seats. Seats 6, all seat belts work. Seats are in good condition, except driver seat is a little worn (we have a seat cover on it). Cruise control works, but is disconnected. Heat works great. Original radio still in place. Original rear defrost motor still in place. Original jack. Lights and turn signals work. There is a slow power steering fluid leak that does not inhibit the driving at all.
This car was from Nebraska and I have driven it across several states recently. You can get in and drive it anywhere, I use it as my daily driver. I just got a new car and there is no room in my garage for this one come winter.
Asking $5700obo
