The power antenna had a separate wire power feed that is energized when the radio is manually turned on or when the ignition switch is moved to the start/run position with the radio turned on. This would be without a separate switch to raise and lower the antenna, otherwise.
The issue of "sound" can be variable, unfortunately. Might just be bad speakers or, worst case scenario, bad amplifier outputs. Might need to dummy-up some jumper wires to one of the rear speakers for testing. Is there any static as the volume control is moved from "off" to "on" or lower volume to higher volume, or moving the f/r fader or the side-to-side fader?
What about the antenna lead-in cable? Plugged in or defective?
I believe that the particular radio chassis is not unique to the FMJ cars, but went in all Chrysler products in that model year?
In bench-checking it, be sure to have a speaker to each of the output wires. Otherwise, you might blow the output amps, as I understand it.
Just some recollections,
