WANTED 67 Newport hardtop 2 door complete rocker trim
Most trim is very brand / model / year specific. May not even interchange between a New Yorker and Newport. Unless somebody has specifically looked at this scenario, there probably won't be an answer.
Download a 67 parts book, section 23 you will find the trim pieces for all models, get your correct P/N and then look at the other models to see if you find a match. Once you find the right piece in the pictorial view note the category number ( 23-##- ##) You can use that number to find the p/n for the other models.
Free downloads are available: MyMopar - Mopar Forums & Information - Parts & Accessories Books
If you find your answer please post the results for the next person.
$65 plus shipping driver side molding does have a crack in it
Looks almost exactly like '67 Barracuda rocker trim.
'67 Newport and '67 New Yorker are the same physical molding, just that in the Newport, the black paint is in the recesses. In the NY, the black paint is on the top of the ribs, just the reverse of the Newports. Dodges were 122" wb, Chryslers sedans/hardtops/convertibles were 124" wb.
