barsteel
Hello!
I've been beating my head against a wall trying to get the low beams to work on my '68 300. Yes, I replaced the dimmer switch, no it didn't fix anything. The wiring is bone stock and appears to be in good condition. I ran temporary grounds to the bumpers and to the light housings, no luck. Checked the feed with a test wire and confirmed that the lights are not getting any current.
Could a bad headlight switch cause no low beams?
If not, is there anything else that typically goes wrong with C bodies that would cause the low beams to not work?
Sorry, but this is all new to me...my first C body.
Thanks...
Chris
Thanks...
Chris
