For Sale Formals gone wild... 1-13-18
cantflip
Old Jagoff with a Hat
Orlando, FL
Feedback: 2 / 0 / 0
A little CL search...
1974 Chrysler Imperial
1974 Chrysler Imperial - $8500 (Langley BC)
"65000 original miles garage kept. Full load 440. New carb, brakes and dual exhaust. No rust perfect in and out drive anywhere"
1974 Chrysler Imperial Rear end with disc brakes Rat Rod
1974 Chrysler Imperial Rear end with disc brakes Rat Rod - $275 (athens)
"1974 Chrysler Imperial Rear end with disc brakes. Great for a rat rod or disc brake conversion on your Mopar. Complete and in good condition. The rear end has 3.23 gears but a don't think it's a sure grip.Asking $275."
Mopar REBUILT Factory REAR DISC Brakes From A 1975 Chrysler Imperial
Mopar REBUILT Factory REAR DISC Brakes From A 1975 Chrysler Imperial - $750 (Rancho Cordova)
"I rebuilt this factory REAR DISC Brake system off a 1975 Chrysler Imperial, that was equipped with a 9 1/4" inch axle.
This set up is 100% complete, all there, nothing missing, with all the parking brake mechanism, and parts.
I cleaned all the parts in the solvent tank of Superclean solution, and then soaked the parts in a 5 gallon pail of Evaporust, to remove all the surface rust off the parts, and then painted the rotors and calipers with VHT cast iron grey, high heat paint, and the brackets with Rustoleum black.
Calipers rebuilt with new kits installed, and new brake pads.
The rotors measure in at .980 and .950 thousandths of an inch, all above minimum specifications.
If you know about these Imperial rear disc brake systems you are aware that the rotors alone are obsolete, hens teeth, dinosaur eggs, unobtanium, to find in this day and age, and are very high $$$$$ dollar items.
After you install these new brakes on your vehicle, most likely this will be the last brake job you will ever be doing on it, so years down the road you won't have to search for missing parts.
Naturally with doing a rear disc brake conversion such as this, you need to have the mechanical skill, and ability to do this conversion.
All parts are being sold "as is " condition, what you see in all the pictures.
You will be bending new brake hard lines along the axle tubes to fit.
Adapt parking brake cables to fit the mechanism.
Add a new or rebuilt master cylinder of your choosing, for the larger fluid volume reservoir for now rear disc brakes in the rear.
The left side brakes mount forward, and the right side brakes mount rearward.
Can be used on the 8 3/4, 9 1/4, and 9 3/4, Dana 60, passenger car axles, without difficulty.
On a 8 3/4, and 9 3/4 axle you don't use the 5th, brake backing plate hold down bolt to the axle tube, at the 6 o,clock low position.
Selling everything at $750.00 plus what it takes for the FEDEX people to get all the parts to your zip code.
With insurance, and signature delivery fees included on two packages."
Side Note: You could go with the top axle and do your own work, but the rotors are likely boat anchors. The bottom cleaned up set is a member here...
1975 Chrysler Imperial LeBaron
1975 Chrysler Imperial LeBaron - $5000
"75 Imperial LeBaron crown
440 engine
automatic 727 trans
very low miles
Corinthian leather interior
air conditioning
power windows
power steering
tilt wheel
4 wheel disc brakes
35,000 original miles"
Funny... it hasn't sold yet
1974 440 Big Block Mopar Thermoquad Carb
1974 440 Big Block Mopar Thermoquad Carb - $30 (Dillsburg, PA)
"Big block Mopar 440 4bbl thermoquad, worked when pulled but had old gas in it. Pulled from 1974 Chrysler Imperial. $30"
I kinda want this for the carb core and egr core... but I won't pay to mail it... maybe he'll bring it to Carlisle.
Rebuilt 440 Big Block Mopar Engine and 727 Trans Complete Carb to Pan
Rebuilt 440 Big Block Mopar Engine and 727 Trans Complete Carb to Pan - $4000 (Dillsburg, PA)
"1975 440 Imperial motor(not a motorhome piece) Bored .30 over, cast crank milled for manual trans throwout bearing, heads rebuilt, new pistons/rings/bearings/oil pump/fuel pump/water pump/cam/lifters. Rebuilt by FIT Engines in Dillsburg
Comp Cams Cam Duration at 050 inch Lift: 224 int./230 exh.Valve Lift with Factory Rocker Arm Ratio: 0.477 int./0.480 exh.
Lobe Separation (degrees): 110 Grind Number: CRB XE268H-10.
Edelbrock Performer 440 Intake and Holley 3310 750 Cfm Electric Choke Carb
Complete air cleaner to oil pan, including front drive accessories and a/c compressor.
Included but not in the pictures, new plugs, wires, electronic distributor and coil, belts, hoses, kickdown cable, chrome 440 air cleaner and an aluminum Champion big block radiator for B and E body. Also includes Shumaker conversion mounts to mount in small block B and E body Mopars. Factory exhaust manifolds and Magnaflow head pipes also included.
727 Torqueflite Trans completely rebuilt and resealed with TransGo shift kit installed. Rebuilt by Wayne Myers Transmissions in Dover
New B&M Torque Master 2400 stall converter with matching B&M flexplate also inluded.
The whole setup is less than 6 months old, 0 miles and never fired, most receipts included. I had this whole setup built for my 72 Charger but decided to go another route. $4,000"
Pretty sure this is the same seller.
Doors 1975 chrysler
Doors 1975 chrysler - $1 (Johnstown)
"4 complete doors everything there. Think they are for a 1975 imperial"
I wouldn't want to pay to ship these either, but I'd buy if they were priced right.
1977 Chrysler, 38,000 miles, No Rust New Air Conditioning
1977 Chrysler, 38,000 miles, No Rust New Air Conditioning - $9800 (Live Oak, Fl)
"1977 Chrysler, 38,000 miles, No Rust
Live Oak, Fl 32060
Ice cold Air Conditioning with new
1. Compressor.
2. Dryer
3. Gaskets
4. R-34 Freon conversion.
440 c.i, motor
Air, cruise, ps, pb
I feel the car is drivable.
38,000 original miles runs and drives.
I have the clean Florida title.
440 motor.
New exhaust.
New Michelin tires.
New vinyl roof.
No rust undercarriage Note: See Photos.
Air conditioning.
Come see the car and make an offer."
Blue Pig is still around... Hmmm... considering how long since Michelin has made a white stripe tire... I guess that helps date how long he's been selling.
1976 Chrysler New Yorker Town & Country Wagon Parts
1976 Chrysler New Yorker Town & Country Wagon Parts - $1
"I have various 1976 Chrysler New Yorker Town & Country Station Wagon Parts. If you are interested please send your phone number."
76 new yourker
76 new yourker - $3500 (Canton)
"I have a 1976 Chrysler new yorker I'm the second owner it's all Original except it's on its 3rd motor it has new wheel cylinders,alternator,voltage regulator, and water pump interior is red crushed velour with pillow seats front and rear power windows power driver seat door locks it is an ac car it take r12 hasn't been converted over to 22a yet all I have is a picture of the outide for now I will take more price is 5500 feel free to ask questions it also has 5 new tires on it"
1976 Chrysler New Yorker Brougham
1976 Chrysler New Yorker Brougham - $4850 (Battle Creek)
"1976 Chrysler New Yorker - Brougham
The Car is the dull beige/yellow int/ext., it has a 440 big block, with automatic trans, 66k miles.
The lights all work even the flip down headlight doors.
The body has some scratches and dings, previous owner tried parking in a 1950's single car garage (oops!)
The car runs and drives but would need work to be a daily driver. It is a fantastic car for restoration as the body has a solid floor pan, trunk pan, rockers, frame, all solid.
I am not the original owner and I have no emotional attachment to the car. If you're ready to buy I'm ready to sell. Thanks for looking I look forward to talking with you."
1976 Chrysler New Yorker - $3995 (West york)
"1976 Chrysler New Yorker 95,725 miles this car is in great condition all around drive it home anywhere"
1976 chrysler New Yorker brougham 2 door
1976 chrysler New Yorker brougham 2 door - $4000 (Gibbon glade pa)
"Beautiful car body is great no rust has perfect interior everything works drive great has 440 v8 as well no trades"
1976 Chrysler New Yorker - $10000 (spring hill)
"2 door hardtop, Hearst equipped Very limited production, 440 4 speed ps pb She's a beauty. For Sale, Trade, OBO"
Might be a good time to rescue Stan's car from another Porsche owner...
1977 Chrysler New Yorker Brougham
1977 Chrysler New Yorker Brougham - $9500 (Mechanicsille)
"This is a rare Garage Find. 1977 Chrysler New Yorker Brougham. 49,229 original miles. I am the second owner, first owner passed away. This beauty has been garage kept for the past 40 years. Exterior and interior are in excellent shape. Engine is a 440. The car has been stored in Virginia, there is no rust. This car runs like a dream, floats like an angel. It truly has been preserved like the ultimate luxury vehicle it is. You would need to transport the car if purchased. Heads will turn if you own and drive this beauty for yourself. Thanks for looking."
1977 Chrysler New Yorker Brougham 1 owner 47K miles
1977 Chrysler New Yorker Brougham 1 owner 47K miles - $4850 (Ronkonkoma)
"Original one owner car that is my accountants. He got it after his uncle passed about 5 years ago and we have been driving it since. 47,000 original miles. Garaged whole life. Interior is in great shape with everything working. Power seats, locks, windows, antenna, steering, brakes and even the headlights and the noise works until you fasten your seat belt. Has tilt steering too. Exterior is nice for a car this old. Top is perfect . Only issue is a scuff on the side that must be 20 years old. Since it never rusted we left it. Make offer!"
CHRYSLER 1977 BRO Beautiful Antique, all Original, 2nd OWNER
CHRYSLER 1977 BRO Beautiful Antique, all Original, 2nd OWNER - $7800 (Martha's Vineyard)
"1977 Chrysler New Yorker Brougham 4 door hardtop with leather tufted seats and 78K original miles . Vehicle is all original and no rust ever. Paint is original with a few small blemishes otherwise looks excellent. Vinyl top is in perfect condition. All records since new, including original purchase order and gas records.. We have the original documentation as to where and when it was purchased when new, where its been during its life all hand written by first owner, all operating instructions and booklet including emission control system. The New Yorker has the 440 engine with the factory Electronic lean burn system, nearly new tires, leather interior and factory air conditioning. The paint on this car is very nice with absolutely no rust and has always been garaged This is an absolutely super nice automobile that you can show and drive. Like having your living room sofa in the car. Rides like a dream and floats down the road. A true classic, all power and style when cars were made the way they should be. Was asking $7800.00 but been sitting in the garage last couple years and needs heater core, heater control repair and has a slight skip (plugs, wires, cap and rotor have been replaced). May need a new coil or carb cleanout I do not have time to to check the issue so will consider any reasonable offers. All travel records and original purchase order, receipts call show contact info
Will listen to reasonable offer but please I am not in need just to many things on the table right now."
Chrysler New Yorker Vintage 1977 Brougham
Chrysler New Yorker Vintage 1977 Brougham - $18000
"Vintage New Yorker for an old school car appreciator. Drives well, very low mileage; contact for more details."
1977 Chrysler New Yorker Brougham - $5500 (Fishers)
"I'm selling my favorite Car. 1977 Chrysler New Yorker Brougham. Green exterior, Green Interior. Interior is 9.5/10. Exterior is 7.5/10. Just a little rust behind rear wheels and a couple dings, overall this car is in great shape. All original except for new white wall tires. 440 V8 Engine Runs and drives great. I'm sad I need to get rid of it but need the room in my garage. Asking $5,500 or best reasonable offer."
1977 Chrysler New Yorker 70k original miles
1977 Chrysler New Yorker 70k original miles - $6900 (West palm)
"1977 Chrysler new Yorker origanal 70k miles 440 engine A/C blows cold rust free paint is in great shape runs good very nice Interieor all new tires call for more info"
1977 Chrysler New Yorker - $7500 (West PSL)
"Four door, hard top, white wall tires, very good condition, call Ed show contact info
Was a showcase car!"
1977 Chrysler new Yorker - $6000 (Lakeland)
"Selling a 1977 Chrysler new Yorker 2Dr hardtop. 4 wheel disc brakes rebuilt 440 Mopar performance Cam double roller timing chain edelbrock intake edelbrock carburetor arp fasteners. Nice dual exhaust system w headers dynomax . nice recent paint. Rebuilt transmission w shift improvement kit New vinyl roof. 15x8 Chrysler road wheels with new 255 60 tires. Front and rear sway bars new brakes .new shocks air in rear..very nice burgundy leather interior.Tilt telescopic steering. Factory service manuals and brochures Nice stereo w Bluetooth sub backup camera.mopar performance valve covers and air cleaner. R 134 a.c.. All power windows work great.. Comes with a ton of extra parts lots of n.o.s parts. Super nice car from elderly owner who spared no expense. I just drove 1400.miles from South Carolina to Atlanta to Lakeland Fla.much more to list. Runs spectacularly very nice executive hot rod.I have lots more pictures available. Thanks"
78 Chrysler new Yorker
78 Chrysler new Yorker - $2200 (hayward / castro valley)
"Hi I'm selling my 1978 Chrysler New Yorker this is a very good car to me while I had it. Runs good feels good on the road. Well maintained fresh fluids wires plugs. The car was garage for 4 years. Registration is now up to date and has been smogged recently so there is no need to worry about smog for the next two years. If you don't want the car with the rims let me know I will try to get the stocks as of now I don't have them mainly because I have nowhere to store them. I currently have nowhere to store the car so it's on the street and I always have to move it due to street sweeping and garbage pick up so therefore the cars for sale if you have any questions please give me a call or leave a message at show contact info
my name is Jay for those of you who don't know me."
1978 Chrysler New Yorker - $1 (north Houston)
"Parting out this 78 Chrysler New Yorker, serious inquiries only please show contact info
PARTS ONLY"
1978 chrysler new yorker
1978 chrysler new yorker - $3300
"Has 84,xxx miles, not mint, but very nice cruiser.
400/727
2 door"
Rear caliper rebuild kits also fit other brands, too. Reman calipers (in Cardone) show to fit A- and B-body Mopars' FRONT of the '73-'75 vintage. LOTS of applications for the hardware kits. So, that makes the rotors the key item.
I like that "green one", for its color.
