Hood Hinge Lubrication - '65 300
rexus31
San Gabriel, CA 91775
What's the best way to go about lubricating the hood hinges and torsion bars? WD-40? White lithium grease? What are the lubrication points? I've got an awful squeak and the hood is getting hard to close.
I would be using the white lithium spray in the whole "track" for the torsion bar, as well as spraying some between the roller and the torsion bar.
I tried a lot of stuff. They all did the same thing.
And my OH garage door springs were driving me nutz also. Tried a lot of stuff. They all did the same thing.
Them an OH garage door installer told me to use a spray lube labeled specifically for OH door. I never heard the doors be so quiet. :wideyed:
WAIT! What about my hood hinge's? Hmmmm...
Exactly what I was looking for. :thumbsup:
I would use graphite or white lithium grease. Not a fan of WD40 there are much better high quality sprays although you have to pay up for them.
I use that stuff on everything.
WD40 is not a lubricant. I use white lithium grease and have tried Tri-flow but it doesn't last.
White lithium grease warning: don’t buy it in a spray can! It goes on fine, but then hardens up and is worse than useless as a lubricant.
Buy white lithium grease in a tube, like lubriplate.
First thing is to CLEAN the tracks of old lube and dirt, then lubricate them.
WD40 sucks, don’t bring it home. Buy a good lubricant with Teflon in it, much better! Or aerokroil, they have lubricant or penetrant. Good stuff.
https://www.amazon.com/Aero-Kroil-L...rds=aerokroil&qid=1560873573&s=gateway&sr=8-5
Hadn't thought about it earlier, but a slide-out lubricant from the RV supply would work well too.
You could try dry motorcycle chain lube. Basically solvent propelled graphite. The solvent flashes off and leaves the dry graphite behind. Dirt doesn't stick to it so it doesn't leave a mess.
Kevin
It's a RV thing where they cut out a section to SLIDE OUT so there's more room inside. If you didn't know?
For a lot of applications similar to this, I have used CMD extreme pressure lube. It is fairly easy to keep the application neat and tidy with the tube.
