Guys my '74 fury is a factory 360 SB car but since I own the car I've always had a low vacuum problem at idle
Right now the engine is freshly rebuilt, has new timing gears and chain, XE262H comp cams camshaft, stock heads and pistons and a Street Demon 625 carb but with the engine fully warmed I only get between 10 - 12" of vacuum and other people with the same camshaft ion 318s and 360s claim to have between 17 - 19" of vacuum
My initial timing is 19ª BTDC (is the point with better vacuum signal while idling and without ping at WOT), already tested for vacuum leaks without results, the engine idles at 700 RPM but If I rev it to 1200 RPM the vacuum increases to 17". I don't know if has something to do but when I bought the car there was a vacuum amplifier installed in the intake, I removed it but still have it hanging around
any ideas?
any ideas?
