NS-1 Neutral safety switch, other part #?
Rusty Muffler
Petaluma, Ca.
Hi all, I may need a neutral safety switch and don't want to pay an arm and a leg for it $65. and up!! Is there an alternate number or numbers or equivalent I could try? I'm guessing these were used in many applications? Thanks in advance.
You had better pay attention to the CORRECT one, also.....
The N S 1 , fits 1955 - 1964.....
The N S 9, fits 1963 - 1968......
There is overlap, as you notice, on 1963 & 1964... I would have to get into my catalog for 1963 & 1964 --- because I don't recall off the top of my head what the difference is, but it is clearly spelled out in there..... if anyone needs to know ......
Both of them --- NS 1 and NS9 --- have become roughly $ 65 and up..... there is N O $ 25 switch NEW on either of them for many years now......
Craig.....
Craig.....
Thanks, I forgot to mention my car is a 57 Belvedere 301 V8
So, on a 1957, the NS1 is the common one....
They actually have two (2) different ones for the 1955 - 1964 !!! Listing......
It is based on where they mount, I do recall, Manifold Mounted versus Transmission Mounted... again, I can get into my old catalog to let you know exactly what the difference is..... the oddball one, I actually do much less expensive, because I have quite a few of them, from deals I have bought / places I have closed out...
I will look, and report back to all of you here in a little while...... Craig......
Page 220 in the FSM says tighten switch until electrical contact is made then tighten 1/3-1/2 turn tighter.
Make sure transmission is in neutral.
Make sure the concave of the spring washer faces the transmission.
I thought there was a torque value on these but one did not appear in the FSM.
An N S 1 Standard = 1704283 MOPAR = CH2568 Chrysler === Those are all definitively one and the same....
And here are the applications: ( We should find some way to make this a " sticky " ....
CHRYSLER
1955 - 1958 w / Automatic Transmission / Transmission Mounted == NS 1
1957 - 1958 w / Manual Transmission / Transmission Mounted ==== NS 2
1959 - 1963 w / Automatic Transmission --- ALL ================ NS 1
1959 - 1963 w / Manual Transmission --- ALL ================== NS 4
1964. w/o Console ================================= NS 1
1964. w/ Console & 1965 - 1968 --- ALL ================= NS 9
DODGE
1955 - 1959 w / Automatic Transmission / Transmission Mounted == NS 1
1957 - 1959 w / Manual Transmission/ Transmission Mounted ===== NS 2
1960 - 1961 w / Automatic Transmission/ 1962 - 1963 --- ALL ====== NS 1
1960 - 1961 w / Manual Transmission ========================= NS 4
1962 - 1963 --- ALL --- ===================================== NS 1
1964. w/o Console ================================== NS 1
1964. w / Console & 1965 - 1968 --- ALL ================= NS 9
PLYMOUTH
1955 - 1959 --- ALL --- w / Transmission Mounted =============== NS 1
1960 - 1961 --- ALL --- w / Automatic Transmission ============== NS 1
1960 - 1961 --- ALL --- w / Manual Transmission ================ NS 4
1962 - 1963 --- ALL --- w/ Automatic Transmission ============== NS 1
1964. w / Console & 1965 - 1968 --- ALL ================ NS 9
NS 1 and NS 9 are single pin Neutral Safety Switches, 1969 & up became the 3 pin switch == NS 11 .......
CHRYSLER
DODGE
PLYMOUTH
Nice job Mobileparts, good work, thank you. :)
