Steering column upgrade
Jakenks
Wichita KS
I have a '66 Fury and I understand that this is the last year of the non-collapsing steering column. I'd like to swap in a safer column. Will later model columns swap in? If so, which ones? The car is an old race car and far from original, do I'm flexible
The mounting surfaces and bases are different between 66 & 67. Also the tilt-o-scope wirings are different for those years. The 66 has a flat plate that the column support bolts onto. 67 and up have plastic plugs on the column support and the holes are in different locations. I think there is also a difference in the number of holes. They say nothing is impossible if you have enough money.
