MKTSC
So when I got my car (67 Fury VIP with smog-era 400) the choke blade was held open with a piece of wire:
Previous owner said the choke wouldn't pull off, so he just wired it open. I pulled the carb, rebuilt it, and found a NOS pull off diaphragm on eBay. Put carb back on, and the pull off just doesn't have enough *** to retract. You can apply a slight bit of pressure to the pull off rod, and it'll operate, but won't do it under normal engine vacuum. I put a new hose on and verified that I was getting good vacuum from the port on the back of the carb, and I'm getting plenty of vacuum. Wondering if my NOS pull off is bad. I ordered a quality new one from Quadrajetparts.com.
Really hope that fixes it. Also where's a good place to pick up IGN switched 12v for the supplementary heater on the choke thermostat?
Thanks,
-MK
Thanks,
-MK
