WANTED 15 x8 small bolt wheels
Dallas ward
Lockport
hello I'm looking for a 2 - 15"x 8 small bolt pattern steel wheels with a 5.5 back space
I know they would be custom wheels
And that there are company's that make them
I'm looking for a used set for the rear of car
You have to specify here. Small bolt circle is 4 1/2" to guys that have Imperials with 5" bolt circle wheels.
Sorry I don't
It's a dart custom
B5 blue
Automatic 727 built by Martin Saine
Converter from a&a transmission 3500 stall
8 3/4 489 case with 3:91
Has 14" cheaters on back now with ralleys all around
Engine is a 340 .30 over
Stock forged crank and rods
Polished rods
Edelbrock/Indy joint effort cylinder heads
10:1 sportsman racing products Pistons
Comp solid roller cam
Roller rockers
Performer rpm air gap manifold
Msd dist , coil and msd 2step box
Carb is a custom pro systems Holley hp 750 cfm
Stockton Wheel Stockton Wheel should be able to make them. The centers are interchangeable with the other bolt patterns and the stock 14" and 15" use the same centers.
Alan
i have 2 Abodys myself. My all time favorite is probably a 69 340 Swinger. Do you have a pic of your 69?
Yes
Also has the Mexican hat centers on front wheels now
I have a 67 dart hood that I'm gonna paint flat black with the hemi dart scoop on it
Hav 15" centerline wheels and skinny tires for front and want to run 15" black steel wheels on rear
Seen guys on the a body site with the 15"x8" with 5.5 backspace
I want biggest rim I can fit
They would b a custom rim
I most likely won't be able to find what I need
But it don't hurt to look anyway
If you were to find a ( stock ) 15 x 8 with a 4" bolt circle
Wheel , from what I'm told it would be a ramcharger wheel and are almost impossible to find and I wouldn't know what stock backspace is on that wheel
A 15"x 8" wheel with a 5.5 backspace and a 4" bolt circle is the biggest wheel i could get on my dart
