IronMighty
Another daft question about my new Suburban... Wipers are not working, there's no feed to the switch which I can easily remedy, but in terms of switch operation, does it only twist or should it also push/pull to activate with twisting for varying speed only?
Also understood the screen wash pump was foot operated vacuum system? Found the bracket under the seat and its got an electrical switch fitted... also there doesn't appear to be a washer fluid reservoir, where would this normally be fitted?
Many thanks for your patience whilst I navigate around the vehicle
