Help me out with some pointers....like random modes of failure that come from experience...
1964 Dodge 880. The brakes are inadequate. When the car is off (or brake booster is disconnected) I have a firm pedal. With the car on pedal is soft until last 1/4 or so of travel. Even when depressing the pedal 3/4 or 1/2 the brakes engage and the car will slow. I have to keep my foot down for a seemingly long time to stop the car at speed.
Car has new, dual chamber master (67ish or so Chrysler), new cylinders and shoes on all 4 corners. New soft lines. I've run about a half gallon of brake fluid through the system with a vacuum bleeder at each wheel. In addition to the two person method.
Brakes are adjusted per specs...up until the wheel drags and then off 10 clicks. The fronts are actually of just until the wheel spins. Shoes are on correctly with the smaller, primary shoe on the front.
I should be able to lock the brakes up with ease...I have other drum brake cars that I'm comfortable using in modern traffic...but not this one.
All the parts are Napa (a marginally higher grade of Chineseium)- I had a master fail right out the box from them recently on another car- so that's no guarantee.
I did not have the drums turned (I wouldn't know where to find a shop in this area to do that) and I reused the old hardware. I was hoping to put some miles on the car this summer and this is putting a hamper on it.
I see Scarebird is back in business...I inquired about a kit-but have had no response. I do live in the PNW and no one would argue the benefits of disc brakes in the rain....
I'm running stock 14" wheels and am not changing.
Thoughts?
Thoughts?
