Mopar001
109,000 miles. the engine is REALLY clean on the inside. compression check revealed that #1 has 35lbs of compression and the rest have 85-95lbs. She's been sitting up since 1987. Heads are off and the cylinders look a little worn of course but NO scaring. I'm having the heads redone first. No cracked valves that I can see. While I have the heads off I may as well pull the motor and clean it real good and paint it. May as well change the oil pan gasket and the oil pump. What else should I do while I have it out???
