1970 Chrysler 300 Hurst Rear Wheel Clearance
Steve-43
Torrington, Ct.
I tried to remove rear wheels on my 1970 Chrysler 300 Hurst and had a hard time getting them off. Lack of clearance between brake drums and wheel lip opening. I had to deflate the tires to push in on the sidewalls to drop them down and out. There was no angle to get them out otherwise. Anyone run into this problem before? Solutions?
Did you have the car on a hoist with the rear axle hanging low in the springs?
If you raise the car with a hydraulic jack under the rear axle, that would not alter the gap between rear wheel and wheel lip opening and there is not enough space to get the rear wheel out. That goes for many fuselage models.
The origial bumper jack raised the car up until the rear axle hung free on the respecitve side, so that took care of that problem (but one was likley to scratch the bumper or maybe even bend it a little).
Yes, I had a hydraulic jack under the rear pumpkin and had it up on jack stand. Your solution makes perfect sense. Thank you for pointing me in the right direction. I will jack on the frame-rails and do one side at a time.
Such rear tire/body clearance items seemed to be more prevalent on the Slabe, by observation.
When I upgraded my '67 Newport CE23 to factory station wagon 14x6.5 wheels, with BFG Advantage T/A in P245/70Rx15 size, I jacked up the rear end under the center of the axle, then placed jack stands on the frame rails so the tires were not touching the floor. I then easily let the jack down to ease any possible body flex issues.
With that done, I removed the stock 14x5.5 wheels and P225/75R-14 tires. No problem. Lots of room, even on the side that was a bit tighter. Getting the wider tires and wheels (those old BFGs had wider and thicker sidewalls than normal tires did back then (extra material to protect the white sidewalls from curb contact!), so that extra bit of width offered some real challenges to get the widest part of the tires past the body AND brake drums! I figured out that if the car had had 11x3 rear brakes, it would NOT have worked. But I was able to wrestle things past the tight spot on the tight side and all was well. When I finally upgrade to 15" OEM wheels and normal P225/75Rx15 tires, I do not anticipate any issues. Perhaps this is ONE reason that Chrysler never did put wider than 6.5" wheels on C-bodies, until 1974? I never would have considered that rear brake drum width would affect getting a rear tire changed on the car!
In a shop on a body contact lift, no issues as the rear shocks could be disengaged with the rear leaf springs.
On these cars, the biggest tire was the 9.00x14 on the same 14x6.5" wheels I used. That tire size equates to a section width of 228.6mm, which would relate to a P235/75Rx15 tire size on a 15x6 wheel with OEM backspacing.
What wheels and tire sizes are on your car? Just curious.
Just my experiences and observations,
P23570R15 are going on as new, the old H70-15 polyglas tires are coming off.
If those were the original H70-15 raised white letter Goodyear Polygalss tires, I would think about not trashing but keeping and storing them, these are not reproduced.
Put a tube in them and use them for Display Only, possibly? They've been aged-out of usability for decades on a road-going vehicle.
I would be interested in any rwl H70-15 Polyglas you may have. Connecticut isnt a far drive for me. Thanks, Charles
Don't jack the car up from the axle.
