For Sale 1978 Chrysler New Yorker $3500
1978 Chrysler Newport - $3500 (Naperville)
Running, Driving 1978 Chrysler Newport. 6.6L 400CU V8. 4-Door Hardtop (No B Pillar).
This car is in Excellent Condition.
The interior has no rips or tears or stains. Exterior has no dents or scratches big enough to mention.
This car was garage kept for its whole life and not driven in the snow, there is almost no rust underneath the car.
This car turns heads anywhere you go.
With the 400 CU Engine this car is not slow by any means. Driving 50MPH feels like you're only going 25, and feels like riding on a cloud.
This car is large, just under 19ft long, and can easily fit 6 Adults. It fits fine in normal garages and parking spaces.
Trunk is large enough for a full sized spare, and another 2-3 passengers.
Improvements/Modifications/Restorations
-Lean-Burn system replaced with Electronic Ignition conversion kit
-Carter Thermoquad replaced with Edelbroch 1411 750CFM Electric Choke Carb
-Brake Booster professionally rebuilt
-Entire front brake system replaced, New Calipers, Rotors, Pads and Hubs.
- New Plugs and Wires (Entire New Distributor from Electronic Ignition kit)
-Coolant Flush less than 200 miles ago
-Oil Change less than 200 miles ago
-New Fuel Pump
-2 New Fuel Filters
-New Gas tank (Same kind as original, not a fuel cell)
-New Battery this winter
-New Tires less than 200 miles ago
-Temperature, Volts, Oil pressure and Tachometer Gauges (Back-lights come on with headlights)
-Factory jack in trunk
-Repair Manuals for 1978 Chrysler Dodge Plymouth, brand new
-New Gas cap
-Both wheel skirts
-Factory Bug Guard
-Original Hood Ornament
Issues
-Front right turn signal bulb is out
-AM Radio does not work
-Blower motor is clogged and does not blow
-Wiper Linkage bushing is broken
There is nothing wrong with this car mechanically. You can hop right in and drive just like any other car.
More pictures or Info upon request.
$3500 OBO
Call or Text
630-689-3174
