furyfever
Please PM me if you have a 2 barrel Carter carburetor off of a 67, 68, 69 vintage Mopar that perhaps you have removed to upgrade to a 4 barrel setup. Would be great if it was working reasonably well before you removed it. But...even if it was not, perhaps it has the proper base I'm looking for. I have a 68 Fury III that came with a 2 barrel Carter BBD #4578-S that has the air/fuel mixture holes in the base (at front) filled in with lead (from factory). Car does not idle well...I would like to be able to adjust my air/fuel mixture so...so even if you have a parts carb. I may be able to swap the base out with mine. Thank you!
Below are photos of my carb. If you have nearly the same type...but with adjustment screws down in front, that is what I'm looking for.
Also: If you have the same type but with adjustment screws and do not want to get rid of it...and you know the 4-digit part number (little triangular tag under one of the cover screws) please if you will, e-mail me your number because I may be able to buy a remanufactured carb. at Autozone or Advance Auto. Thanks!
Bob
Bob
