NOT MINE 64 Polara 'Vert AZ
azblackhemi
Waddell AZ
Feedback: 3 / 0 / 0
1964 Dodge Polara Convertible - $6,900 (Mesa) 1964 Dodge Polara Convertible - cars & trucks - by owner - vehicle...
© craigslist - Map data © OpenStreetMap
(google map)
1964 Dodge Polara
condition: good
cylinders: 8 cylinders
drive: rwd
fuel: gas
odometer: 7000
odometer rolled over
paint color: grey
title status: clean
transmission: automatic
Very solid 64 Dodge Convertible with the 318 "Poly" V8. This is a rust free, dent free southern car complete with original sales invoice, owner's manual, and receipts. The car was undercoated which helps explain the solid rockers, fenders, and floors, etc. It was originally white with a light blue top, but was sprayed with a gray undercoating sometime back. It also is a factory a/c car which I think was pretty unusual for a convertible in 1964. Recent work includes valve job, Weiand manifold, Offenhauser 4 barrel carb, gas tank and fuel system clean out, Power steering hoses, water pump, thermostat, and battery. All the glass is good. Gauges work. Brakes are fine. Hydraulic top motor works fine, but it does need a new top.
Interior is complete and front seat needs a redo.
It is a project and needs sorting. The pushbutton transmission needs to be adjusted. Sometimes it doesn't want to go into reverse. Some of the chrome side trim is missing. The tires are just rollers. The trunk is filled with trim, extra radio, the old a/c system, and other various parts. Ready for you to finish it up. I've got a lift so you can check out the car underneath.
Don't text me with an offer. Call me if you want to see the car. Thanks.
Does anyone know what happened with this car? Sold? Anyone have a contact # for Seller? Cam Shaft
