65 chrysler 300
68Nwprt
Florida
What would you pay for this one, considering that it would cost you 300.00 to get it home? Small hole in the driver floor. LR quarter is dented, difficult to see from the picture. Not road ready. Dash pad is cracked and is the front and rear seats need redone.
http://atlanta.craigslist.org/nat/cto/4161574504.html
1965 Chrysler 300 2 dr hardtop, 383 4 bbl, 727 automatic transmission. 68,375 original miles. Excellent driveline. Needs body and interior restoration. Never been in accident. One owner. Can be restored or used for parts. $2,200 or reasonable offer. Cash only.
It all depends on what options it has. Bucket seats with a console? Power Windows? Power Vents? A/C? I probably wouldn't go over $1,500.
that's a column shift non-tilt car, can see it through the back window
You're right, I should looked closer. I don't think I'd buy that one but it all depends on what you want to do with the car. If you are going to do a full blown resto, I'd hold out for one with a lot of options. These cars aren't cheap to restore so the more options it has will make it more desirable should you decide to sell down the road.
FWIW, if you are dead set on buying this car, make sure all the trim is there, especially the lower trim and rear panel trim as theses are unique to the standard 300 model. I would also make sure the grill medallion is uncracked and in decent shape as they aren't reproduced. If the quarter emblems are rough, I can restore them or sell you the plastic inserts to restore yourself. The same can be said for the hubcap medallions; I can restore those too.
