67Monaco
http://www.autotraderclassics.com/classic-car/1968-Dodge-Polara-1800518.xhtml
$14.500 OBO!! Possible trade. I have taken lots of photos through the rebuild of this car, if there is something specific you would like to see I will be more than happy to provide those. Lots of new parts and work completed! Original paint has some thin spots and with a few dents and dings, but it shines. All but one piece of its exterior trim is there. Runs and drives awesome, A/C is very cold and heater is hot. All gauges and lights work. Some small rust holes on the trunk floor. Quarter panels, front fenders, rockers, floor, and frame are all solid. Some specs on the car: 383c.i, 727 A/T, 8 3/4 rear end w/ 2.76 gears & open differential, Factory A/C, Power Steering, Power Brakes. The following is a list of new parts and work performed on this car since January 2014, there approximately 200 miles on this car since all new parts/work completed. Complete disassembly of motor, honed cylinders, Sealed Power piston rings, Main bearings, Rod bearings, Camshaft bearings, Melling oil pump, Summit Racing camshaft P/N:SUM-6400 and hydraulic lifters, Brass freeze plugs, All seals and gaskets, Aluminum water pump housing, Water pump, Alternator, Electronic voltage regulator, Electronic distributor and control unit, Sanden A/C compressor, condenser, and all under hood components to properly convert to R134, Weiand four barrel intake manifold, Holley Street Demon 4bbl, 625cfm, electric choke carburetor, Fuel pump, Fan clutch, Aluminum 3 row radiator, Spark plugs and wires, All hoses and belts, Power steering pump, steering gear box, tie rods, pitman arm, idler arm, 2 1/4in. dual exhaust, Gas tank & sending unit, In dash A/C and heater control switch, A/C blower motor, Heater core, Drive line u-joints, Wheels- 17x7 & 17x9.5 Wrapped in Nitto 555 tires 235/45 17 & 275/40 17, KYB Gas-a-Just shocks on all four corners, Addco rear sway bar
, Front suspension bushings, ball joints, and wheel bearings, Front disc brake conversion with all new brake components (rotors, calipers, rubber brake lines, master cylinder, power brake booster), Rear brake shoes, wheel cylinders, Rear axle seals, rear axle bearings repacked, Reupholstered front and rear bench seats, Walnut trim steering wheel, Dynamat, carpet & headliner, Dash pads and sail panels recovered, 4 window cranks, Windshield, Lots of new hardware.
