JeeperBillMI
I was looking at an old thread while researching body mount bushings for a Plymouth wagon. Rather than resurrect an ancient thread I am starting this new one. I have other brand X cars in the stable and my 69 Camaro Convertible has a front subframe with rubber bushing mounts. I am not sure if the bolt size will work with those bushings but the GM mounts are supporting the whole body on 4 molded bushings to the sub-frame. You would have to buy 2 additional bushings if they match up size and function wise. Another alternative would be to look at body to frame mounts for older Dodge Durango with a frame and or Dodge Rams. I don’t think the Ram or Durango bushings would be as good because the body is just resting on a frame as opposed to being part of the suspension technically on the C-body. The modern Mopar bushings would also be metric likely 14mm and that could also cause clearance problems for the original sized bolts. Just my suggestions and hopefully this will help somebody. At least it may save some regulation hockey pucks from being slaughtered.
