Wildaugust
If I'm reading the FSM correctly, in order to replace a bulb, you just remove the two screws and the lens comes off? I took out the two screws and then just spent well over an hour trying to remove the lens from the front passenger side. I still haven't been able to get to budge. It seems like either something else is holding it or it has been glued in place. I don't want to pry to much for fear of breaking it.
I only need to remove one lens, but just to see if the others would come off, I tried two of them. Again removed the two screws and no luck.
Am I doing it right or am I missing a step somewhere?
