ALLAN
its only to be expected in a 50 year old car I guess, after some poking about I feel the air-con on our 318 70 Polara isn't what it left the factory with, the organ stop selector in the cab operates through one big electrical block (manual shows 3 smaller blocks) the demist manifold has been adjusted and I can't see any connection with the rest of the system. Most annoyingly the pulley setup under the hood is different, no standard belts fit, I've had to measure and get some supplied, should there be an idler pulley? I have a twin belt system looping from the bottom (crank )- alternator- then air con pump. Oddly though it all seems to work, best left as is .If only I could remember what combination of switches does what,
for what we paid for this little gem I'm amaised it's got wheels let alone working air con,
