Did your cars have the factory undercoat? THAT can make a difference.
Several years ago, on BarnFinds.com, there was a '75 small Fury for sale, with rust issues on the rh b-pillar (it was a 2dr hardtop). Seems that all of those different welded panels were very rusty. ALSO the vehicle had had a name-brand rust prevention compound applied in that area. Whomever did the application, where small holes were drilled so the dispensing wand could be inserted, did something wrong. OR the company didn't fully know how the cars were built! The rust prevention compound all pooled above where the rust was, rust obviously caused because moisture was trapped and stayed for extended periods of time. It was all below the door striker, from the supplied pictures. You could also see where the compound stopped and trapped the moisture, which could not evaporate. Otherwise, the car looked about normal for that age of car. Seems like it was in the NC area?
The other thing is that GMs typically had none of the protective dips. Ever seen a rusted frame? Which only had "black paint" as its major rust preventative? Even on Corvettes?
As good as they might not have been, they were more sophisticated than what anybody else was doing with unit-body construction back then, from what I could tell.
Seems like there is a thread in here of the most common rust places on the fuselage cars? Even the formals? And how they were repaired.
One side issue would be that the Chrysler products tended to last longer than similar GM cars did, so any "short-cuts" which were made tend to be more prevalent as the cars got older. Chrysler products might have been #3 in sales volume, but typically #1 in long-term durability, by observation. Every now and then, I'll see a '70s Valiant on the road (unrestored and still going) and TRY to remember the last time I saw a similar unrestored '70s Chevy Nova on the road.
