For Sale Chrysler New Yorker - $6400
67newport
eastern oh
Feedback: 1 / 0 / 2
Chrysler New Yorker
1941 Chrysler New Yorker 4 door sedan runs and drive great, Straight 8 flathead, has 12v radio but the rest of the system is still 6v positive ground. Has a 6v electric fuel pump.6v Alternator. Wheel cylinders and shoes were replaced but the master cylinder has a slow leak back into the resevoir. Holds pressure for the duration of the drive. Might need to be used with mineral oil only and not brake fluid. Has the fluid drive semi manual transmission with overdrive which works great. 3 on the tree. You can drive it as an automatic or manual fun to drive shifts smoothly. All the gauges work heat and defrost work, self winding clock works. Headliner is in great shape not a single tear seats are in great shape with 2 patches on the drivers seat. I have the door panels off they need to be redone and a new carpet also, body and frame are solid. Rust throughs in the rear passenger fender corners and spot in the truck. Any questions please email me.
