WANTED Cruise Control Carb Linkage.
shooter65
Hi, I'm looking for the cruise control arm that is on the carb linkage. This is a 69 Sport Fury with a 440 Super Commando.
Hello Everyone,
First, thanks Kernel Sanders. Unfortunately this does not properly clear on my carb. I have a 4640S Carter. I suspect that the one you had was from a Holley that was on a 440, not 440 HP. If you notice in the pics above, the one I got from Kernel has the proper bend at the top but the bottom is pretty much straight. Mine is/was shaped like a boom-a-rang.
So, I'm still looking for the carb armature that would be on a 440 HP with the 4640S Carter carb. I know this is going to be a needle in a hay stack because I doubt many 440 HP's had cruise.
Thanks
