Ok I purchased an 83 D350 crew cab with power windows and locks in the front and manual in the rear. Both power windows were inoperable at purchase as were the locks.
I pulled the regulators and motors the drivers side motor was toast. I rebuilt both motors and replaced the drivers side regulator that was binding ( probably caused the motor to fail). I reinstalled and checked the function of both motors and windows with an external 12V source, both worked fantastic. Now on to the wiring .i have checked both switches with an ohm meter and they appear to be working correctly transferring current. The drivers side window works, but the passenger side will not. Here is what it is doing:
The following are the voltage readings atthe wires going to the motor on passenger side
Drivers side switch up
VT-WT wire 1.6V
PK-WT wire 10.3 V
Drivers side switch down
VT-WT wire 10.3V
PK-WT wire 1.6V
Passenger side switch up
VT-WT wire 12v
PK-WT wire 12v
Passenger side switch down
VT-WT wire 12V
PK-WT wire 1.3V
I know this is a c body forum, but talks expertise and all things wiring is why I come to you. Once I get the wiring sorted I plan on adding relays . All help appreciated seems the same voltage out of passenger side switch up is abnormal. I have attached a wiring diagram from FSM and pictures
VT-WT wire 1.6V
PK-WT wire 10.3 V
VT-WT wire 10.3V
PK-WT wire 1.6V
VT-WT wire 12v
PK-WT wire 12v
VT-WT wire 12V
PK-WT wire 1.3V
