mopar_4life
Hello,
I'm changing out the braking system in my 65. It has factory power drum brakes.
I know that I'll be going the scarebird setup for the front. Powerstop calipers(no cores and powder-coated red!!!!(who cares right) I want the powder coating) for 10 extra bucks its a no brainer, I'll use drilled and slotted rotors for the front (I run them on everything that I own and it will make the biggest difference). And some good lifetime warranty pads from the Zone
I was considering the rear but I think it is waste of time/money to go disc in the rear.
I know that I need a new master cylinder for disc setup (68 and newer?) and a prop valve (going adjustable). I have all new lines from inline tube with dual conversion already.
My brake booster looks pretty rough and I figured that replacing it would be best. Should I go with the single diaphragm like it is currently or try to find a dual diaphragm set up? Would it be a waste of money/time?
What else am I forgetting?
Thanks
Eric
Thanks
Eric
